Hello,
I’m using the KMotion_dotNet library for a motion control application. I can successfully configure the motion control axes by the following methods:
a) The “Config and Flash” screen in KMotion,
b) Compiling and running a c-program from the “C Program” screen in KMotion
c) Downloading the C-program into user memory and configure so that it launches on power-up.
However, I can’t do something like this:
String result = kmcontroller.CompileAndLoadCoff(0, "C:\\init.c", false);
I’m not getting anything in String result except a bunch of white space, and nothing in error or message logs, and it’s not creating a .out file
I’m not having any other problems moving the axes using the KMotion_dotNet library once I get it configured.
Any hints?
Toby Rule
